1 - 20 of 23 Posts
thats a good overclock and the vcore isnt that high... it also depends on the temperature as well
that prescott can take a hell of a lot tho so dont worry much
and when I say it depends on the temperature, that means you should give us more info on what its running at temp wise
depends what your settings are for doom 3 but that sounds about right... your graphic card simply isnt powerful enough to run the game well... you could try low quality at 640 and turn off all special effects, antialiasing and anisotropic filtering
Discussion Starter · #14 ·
Originally Posted by remote_username
i'd say if you want to oc more get some good ram or hold the oc and get a new gfx card with some good ram if you keep the good temps you might get 4 ghz
Gimme money first lol!
Originally Posted by SniperGX
Is it normal for me for run DOOM III at about 2 fps with this cpu and a GeForce4 MX 440(64 MB) with 512 MB of ram?
wat res and detail u trying to play it at - usually u wont get near a resonable fps on that card unless its @ 640*480 /low
I'm afraid having that graphics in your rig is a bit like having a lawnmower engine in a Ferrari.
Start saving and remove the bottleneck in your system.
Discussion Starter · #19 ·
I guess I have to do more scamming and hacking aahh. Im trying to quit but it is just so hard! :aacool:
Any good games that run good on 64 MB?
Half-life 2 runs pretty decent.
I'm not sure what games would run well on your graphics card other than the best games of all time. Warcraft 3 & The Frozen throne
1 - 20 of 23 Posts
