1 - 4 of 4 Posts
My pressy is going NUTS.... Just using 2 toast.exe programs(like prime only with a devil on it
) and going at 100% proccesor usage. Now my temp was 44 - 47 MAX... I can't believe that, he's 600 mhz overclock, that's like OMG(imo :$) Now I want to go to 3.7. That will lead me to 250 fsb ... isn't that a little bit high? My brother says it it very high. And i'm using stock cooling ... Anybody know is 250 is to high ?
If your temps are fine and cpu is stable, high fsb does not hurt anything.... infact some people when using stock cooling drop down the multi on higher cpu's and run high FSB's like 300 or so. But since you have a 530, you don't exactly have that, but its ok, don't worry about fsb
1 - 4 of 4 Posts
