1 - 3 of 3 Posts
I have a DD12v which comes with 3/8" fittings only, and I ordered 3/8" to 1/2" adaptors for it but I was only shipped 1. I guess I will order another one but for now for leak testing would it be ok to use 7/16 tubing on the one 3/8 fitting?
<tr>
<div>
Originally Posted by <strong>Frozenshinobi</strong>
</div>
<div style="font-style:italic">I have a DD12v which comes with 3/8" fittings only, and I ordered 3/8" to 1/2" adaptors for it but I was only shipped 1. I guess I will order another one but for now for leak testing would it be ok to use 7/16 tubing on the one 3/8 fitting?</div>
</td>
</tr>
</table>
</div> I dont know..Just stick a worm drive clamp or a couple of zip-ties on it put it where it wont leak on anything and try it...
Cut a 1 inch peice of 3/8 ID tubing and slip it over the barb then put your 1/2" ID tubing over that and clamp, instant, cheap adaptor.
Reactions: ira-k
1 - 3 of 3 Posts
