3.93GHz C2Q Q6600 with 1.472v
866 Views 22 Replies 14 Participants Last post by  10acjed
Well I just got my chip to 3.93GHz, I am posting a SS as well as a CPU-Z validation link, I cannot seem to get it to 4GHz but don't know the in's and out's of the board yet, the chip is also for sale if you are interested
1 - 20 of 23 Posts
That's awesome, gratz!!! Can you go higher? or does it require too much voltage or produce too much heat?
Nice, I can't even get 3.6 with 1.4v.
what is this a golden chip?
Nice overclock. Could just be your ram that is crappy out.
AT 4.0ghz with a 9x multi, you are pushing those OCZs close to 900mhz.
I am sure it can go higher I just don't know what to set for CPU VTT and PLL as well as the GTL reference voltages, it will post at 4GHz but BSOD's before I get to the desktop
EDIT> This is a 780i so my ram is set independently, its running at 800MHz
Originally Posted by microman
i doubt thats stable.
I haven't tested that yet but I am typing this message on that OC, will test stability shortly
is that a stable oc or just good enough to boot into windows.
EDIT: whoops didnt see post above ^^
I can't do 3.4 at any voltage. And nice overclock by the way.
what i can say with an extensive knowledge of Q6600's is this, stable or not that chip has massive potential.
Well I just tested stability and it didn't BSOD but by the time a minute had passed temps were up to 80C and I stopped the test. The Xiggy, while a good cooler cannot cool a chip this hot. I will be getting WC soon and will be trying again but my 24/7 will remain 3.6GHz at 1.344v where my temps stay under 60C
no try intel burn test
It will also do 3.83ghz with less than 1.4v, and Microman I plan on getting a DICE pot soon! Plus my 9800GX2 should be here this week
with dice and a gx2 you could pull 25k in 06 no problem with this chip
Same here. Been at 1.55 @BIOS but nothing...
1 - 20 of 23 Posts
