Hey folders.
I am having trouble running my third 8800GTS 512 without overheating the GPUs.
I had 3 511's running, according to FahMon, when my system crashed. I was at work at the time, so I am assuming it was an issue with heat. When I left it, 2 GPUs were running the 511's, and were hitting temps in the mid 80's. I turned the fans up to get them back down under 80*. Apparently, the third 511 was just too much.
I haven't run the third card since then, and temps have been normal on the remaining 2 cards.
I was wondering if anyone could recommend a good air cooling solution for running 3 cards, one on top of the other. This PC sits in my living room, so it needs to be a noise-friendly solution. I don't mind some noise. It just can't be over the top
Thanks
Thanks
