1 - 20 of 20 Posts
Nvidia Enthusiast
my cpu is not stable at 3GHz with 4th core unlocked but it is if i run it at 2.73Ghz what is better for games like GTA 4 and BC2?
Nvidia Enthusiast
Originally Posted by Wassap
i would go with 4 cores at lower frecuency.
so 4 at 2.7 will beat my old 9750?
Programmer
4 cores at 2.7 is better than 3 at 3ghz if whatever you are doing takes full advantage of all 4 cores.
Nvidia Enthusiast
will bc2 run smoother with 4?
Cores > Clock speed. And anything quad will beat the 9750...the first generation of Phenom's were frankly a disappointment. Phenom II's were loads better. What CPU Are you talking about, the Athlon II X3 unlocked to an X4?
And yes, BFBC2 loves cores.
Nvidia Enthusiast
Originally Posted by jellis142
Cores > Clock speed. And anything quad will be the 9750...the first generation of Phenom's were frankly a disappointment. Phenom II's were loads better. What CPU Are you talking about, the Athlon II X3 unlocked to an X4?
Phenom II X3 710
not to sound like an a-hole or anything, but try them both and post results. I would definitely like to know for future reference.
Nvidia Enthusiast
Discussion Starter · #12 ·
i just tested BC 2 maxed and i got 23 fps no idea why but game was only using 34% of my GPUs
Yep, unlock the core and keep it at stock speeds is my vote.
okay i'll go reset to stock and unlock the core brb ill post results
34% of gpu? weird son.
Most likely its because of your resolution being so low, without a higher resolution, your game will be more cpu bound. A higher clock will give you better performance at your resolution. If you get a larger monitor, the quad will give you better performance.
BFBC2, i don't know
GTA IV will appreciate that 4th core though. on my 720 i gained about 10fps at 1280x1024 from going from 3 cores to 4
Both those games like 4 cores.
Stay with 4 cores @ 2.7Ghz.
Nvidia Enthusiast
Discussion Starter · #18 ·
1 - 20 of 20 Posts
