1 - 20 of 28 Posts
Running beautifully going to try and push it further so far it's running stable on prime have quite a few hours to go tho only running 40C under load going to try and push it further. My goal is 3.2 HOPEFULLY
1.55 but i could probably take it down it's what i had my venice chip at. OOPs forgot to check that
Discussion Starter · #6 ·
Folding is the real reason i got it but have to put it through it's paces on prime so it'll be down for a little bit so i kicked on my other desktop to take up some slack!!!
40C underfull load and 28 idle or so i have a bit of room left depends on if i have to crank up the vcore anymore really
It just crashed man back to the drawing board trying 1.66 divider 250fsb 12x multi 8-4-4-3 timing and a 1.5 voltage 2.8 ram voltage
Discussion Starter · #11 ·
I think mine is a kab3e
Discussion Starter · #12 ·
Hey guys i think i got it stable had to crank the VCORE to 1.65 running a 49C full load so far so good. Kept lower and raising but it would barely post at 1.55 and kept hanging during prime. PRAY!!!!!!!!!!!
Discussion Starter · #14 ·
On what exactly? The proc is 2.4 stock
Discussion Starter · #16 ·
how much cache does the 4400 have mine has 1mb
Originally Posted by fiendofmine
he should have gotten the 4400+, double the cache, and OC's about .6 ghz aswell
dunno where your getting that, but the 4400+ is dual core, the 4000+ is not. Also the 4400+ is Toledo which tends to OC less than the Manchester core dual cores.
Discussion Starter · #19 ·
I posted a pic of the screen shot
1 - 20 of 28 Posts
