What do you plan on cooling? Cpu? GFX? That should be a good start, but it all depends on what you are planning to cool. I got my first set-up used on here cheap. If you piece it together, you can find some good deals. IMO, the only things worth coolling are CPU and GFX cards. If you can, try to run 2 separate loops.
