1 - 17 of 17 Posts
My question is, Does it matter what the multiplier is as well as the bus? WHich makes a bigger difference? Is there a difference with a higher fsb and lower bus w/ the same mhz?
Filthy Casual
I've heard that the higher FSB at the same frequency (300 x 8 vs 240 x 10) is supposed to be faster, but I haven't seen any noticeable gain. There are supposedly some programs that utilize massive FSB over pure speed, but I'm yet to find one.
Reactions: Xeoc
I always like tho have a higher FSB so I'd choose 300x8.<br><br>
That way you Ram & Chipset are running at the same higher rate........I think thats how it works anyway
Reactions: Xeoc
9 Cans of Ravioli
Assuming RAM speed is the same, doesn't matter.<br><br>
There will be a difference, but benchmarks probably couldn't even pick it up.
Faster ram speed is usually better.
Reactions: Xeoc
Discussion Starter #7
<div>Originally Posted by <strong>boredom</strong> <a href="showthread.php?s=f0ff622456a527c34b14aeab359ee59d&p=1395007#post1395007"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">For the CPU it doesn't matter, for your RAM it does<br><br>
Are you running 1:1 at 240x10?</div>
</td>
</tr></table></div>
No, I'm running 227x11 @ 5:6 divider
Discussion Starter #8
<div>Originally Posted by <strong>The Pook</strong> <a href="showthread.php?s=f0ff622456a527c34b14aeab359ee59d&p=1395014#post1395014"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">Assuming RAM speed is the same, doesn't matter.<br><br>
There will be a difference, but benchmarks probably couldn't even pick it up.</div>
</td>
</tr></table></div>
I don't really care about benchies, I'm talking about games. Will there be a diff in games 300x8 vs 227x11? 227 ram running 5:6 while 300 ram runnign 1:2
<div>Originally Posted by <strong>Xeoc</strong> <a href="showthread.php?s=f0ff622456a527c34b14aeab359ee59d&p=1395023#post1395023"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">I don't really care about benchies, I'm talking about games. Will there be a diff in games 300x8 vs 227x11? 227 ram running 5:6 while 300 ram runnign 1:2</div>
</td>
</tr></table></div>
No
Discussion Starter #10
<div>Originally Posted by <strong>boredom</strong> <a href="showthread.php?s=f0ff622456a527c34b14aeab359ee59d&p=1395026#post1395026"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">No</div>
</td>
</tr></table></div>
<br>
Thanks
Although faster ram speed would be ideal, ex. 1:1, AMD systems run better with tight timings and a lower memory freq. versus loose timings and higher bandwith.
it can't hurt though....if your board will run it...might as well. You might be able to get a bit of extra performance...FSB is the communication tool of everythign in your computer...other than teh Hyper Transport thinger...
Discussion Starter #13
<tr>
<div>
Originally Posted by <strong>Sideburns</strong>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1395053#post1395053" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">it can't hurt though....if your board will run it...might as well. You might be able to get a bit of extra performance...FSB is the communication tool of everythign in your computer...other than teh Hyper Transport thinger...</div>
</td>
</tr>
</table>
</div><br />
So a higher htt doesn't do anything?
Fsb...
Keep the HTT as close to 1000 an possible for the memory. The only way it hurts if it's excessively low. <br />
4x up to 260 3x beyond that.<br />
Some MBs are fine above 1000, 1080 is a known wall with many MBs but some can excede that and be stable but there is no advantage to it.
Discussion Starter #16
<div>Originally Posted by <strong>The Duke</strong> <a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1396960#post1396960"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">Keep the HTT as close to 1000 an possible for the memory. The only way it hurts if it's excessively low.<br>
4x up to 260 3x beyond that.<br>
Some MBs are fine above 1000, 1080 is a known wall with many MBs but some can excede that and be stable but there is no advantage to it.</div>
</td>
</tr></table></div>
<br>
Thanks. So 1150 vs 920 theres no diff?
Which ever one uses 1:1 if any is the best because it allows to have tighter secondary timings.<br><br><div style="margin:20px;margin-top:5px;">
<div>Originally Posted by <strong>TheLegend</strong> <a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1395049#post1395049"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">Although faster ram speed would be ideal, ex. 1:1, AMD systems run better with tight timings and a lower memory freq. versus loose timings and higher bandwith.</div>
</td>
</tr></table></div>
Grossly wrong.<br><br><div style="margin:20px;margin-top:5px;">
<div>Originally Posted by <strong>Xeoc</strong> <a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1397028#post1397028"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">Thanks. So 1150 vs 920 theres no diff?</div>
</td>
</tr></table></div>
If your MoBo can pull it off, do it. OCing my HTT to 1320 stabilized my ram overclock by 5MHz (ON BH-5 at it's limit 5MHz is big) It allowed me to run near 3.0GHz on the next higher divider and added 3.5k+ to my 3dmark01 score.
1 - 17 of 17 Posts
