1 - 20 of 23 Posts
Hey All,
Just got my 3200 Venice E6 running at 2.7ghz with 1.45v on the vCore. Ive got stock air cooling
My temps are:
semi-use (firefox, winamp, msn messenger etc) - ~39*C
Load - get back to me on that one...i seriously need to be careful
ive attached the CPU-Z
Edit: i changed the title (better descroption)
Administrator
Originally Posted by The_Jester
Hey All,
My temps are:
That is one sweet overclock form what i can see there. Well done mate.
Hey All,
My temps are:
Nice job.
Very good indeed
Get OCCT and Prime 95 and LOAD that sucker up for stability testing and temp check!
Discussion Starter #5
I 1m'd superpi in 36 seconds. I might tighten the CAS. ill see if it runs at 2.5 okay.
Hey All,
My temps are:
Very nice indeed!
As The Duke said, run those stability test. OCCT, Prime95 and/or Stress Prime. Just to be safe, I would get an after makrket cooler if you can afford one. Heatsinkfactory.com usually has great deals. I got my Zalman $12 bucks cheaper there than at newegg.
Discussion Starter #7
im deffinatley getting a Big Typhoon....DEFFINATLEY!
i should be able to get it next friday - maybe earlier. I hope ill be hitting 3.0 with it. I'll not get my hopes up though.
You might need to get even better cooling than the TT BT to get 3.0 with your chip. It is possible but that is a 50% OC for your CPU.
It will sure help keep it cool
I went with the screws up from the bottom and had to grind the heads down a bit for board to base clearance. Then I used dubble nuts, one under the retainer and one on top, drew down the FHS then drew up the bottom ones to lock em in place. All in all well worth it, the screws from the top are a PITA! Not to mention they were to short
Discussion Starter #10
whats better? WC? I cant afford that, atm - Ill go water, when I get the money
TT BT is definetely the best for air, I would just be careful at 3.0
It would be cool to see you get that out of your 3200
EDIT: What does atm mean? Excuse my ignorance
Discussion Starter #12
Yeah - it would be awesome
I was gunna buy another stick of RAM but ill go against that and get the BT TT
edit: ATM means at the minute - i shouldnt abbreviate but i spend too much time on msn and its become a habit
Just remember to save the stock FHS... if you ever need to RMA you better have it!
Discussion Starter #14
yeah - i wont get rid of that, lol
Lol! thanks! I don't mind abreviations
I just don't know them all.
Discussion Starter #16
what does everyone think about risking 2.8?
bah, damn you E6 stepping! MY E3 needs like 1.48V just for 2.6, where its unstable as trying to stand on one leg after having 4 beers and being on a little boat in a huge sea when its a hurricane!
Other than my envy i must congratulate you with a nice overclock
you can try going any further but before we'd like to see the load temps please
And for a watercooling setup... you could start with tt bigwater
their new version seem much better than mine :S
Discussion Starter #19
im going for the OCCT stress test - ive never used it before and would like to see what its like.
Ill post a screeny of the temps
i must pre-warn you! My motherboard lies about my temps! Minus 10 to 15 degrees and thats where my true temps lie. This is a flaw in the ax8 (otherwise a good board)
Discussion Starter #20
NOOO!! its unstable! Prime95 encountered an error after like 1 second.
OCCT kept locking up on me, so i used prime95.
My temps get to around 70 celcius according to speedfan. Its actually around 55-60
do games count as testing? lol
1 - 20 of 23 Posts
