1 - 20 of 39 Posts
very impressive man... wish i had that good of an oc... i think i would have phase change too lol looks awesome though! great job
Vcore? What is the maximum memory speed of your particular modules? Try to bring the divider up a bit, you're running it super-slow.
How can you have that temp ???
-22C and -8C
however somtime too cold may not good for your CPU !!!
....You did very nice job
Tranphuloc, I was thinking the same thing about his temperatures being unhealthy. I guess they're fine though since it's stable at 3 GHz.
He got those temperatures using phase change cooling by the way.
"too cold" is only bad if the CPU has a cold bug, or if it wasnt prepared enough or correctly for the cooling. Though I suppose there may be some temp that CPU's crap out, no ones reaced it yet.
Vcore-1.58
I can't bring the divider up anymore. On my mobo it jumps from 266 to 333 and then makes it unstable. Im just gonnahave to buy some ddr600 ram
Cold bug = cold soder (im assuming, am i right?) something is not completely connected to something else and when the cpu heats up the alloy's expand completeing the electrical connection being that cold means that the proc could not heat up enough thus not function.
Originally Posted by Evolutionsentra
Vcore-1.58
wow, what mobo you have? I can't seem to get stable 2.0 ghz lol oh well
nice chip and overclock...I want to see some bench numbers, superpi1M and such. You could sell that memory you have and get a good set for $150
You get a rep point for having the highest clocked 3200+ Venice I've seen, having it STABLE, AND providing a validation.
<3
But yea, for a CPU like that I'd definitely upgrade my RAM lol.
thats not a record, ncsa has his at 3.2 or 3.4 i think...and really the chip doesnt matter as long as the temps are right...you could have the crappiest cpu but i guarantee youd still get 3.0
1 - 20 of 39 Posts
