1 - 5 of 5 Posts
Phenomenologist
gamersnexus, buildzoid, and many others OC ram and post FPS results, but they use a 2080 ti at 1080p (unrealistic)
does anyone know how much FPS I would gain at 1440p with everything the same on a more realistic system, say a 2070 super and ryzen 3700x at 1440p high refresh.?
the 16 16 16 will be muich better.
I play warzone and i went from a 3600 cl18 kit to 3800cl16 and the difference was clear to see. avg fps was from 103ish to about 110ish
1440p ultrawide + 2080 super
Edgy & on the edge
~10-15 fps average
~10-15 fps 1% low & 0.1% low
Reactions: caenlen
cl 18 3600mhz is basically the same price as cl16 3200mhz so I wouldn't consider 3200mhz an option on Ryzen. As to the performance difference between 18-22-22 and 16-16-16 probably under 5% difference with a 2070super, 1% and 0.1% lows might see a bigger difference.
Phenomenologist
Discussion Starter #5
thread can be closed, answers seem to be in line with what I was expecting, thanks!
1 - 5 of 5 Posts
