1 - 9 of 9 Posts
Heya guys! I've hit a wall
I'm pretty sure the problem lies in either my budget ram or my psu. here are my settings..
Httx3
HTT-260
vcore-1.55
ram voltage-2.5
I'm running a devider and no matter how high or low i make it i just cant get the cpu past 2.7! I upped the vcore to 1.60 and even 1.65 and i still cant get it to run higher then 2.7.. Any ideas? I'm running a 350watt psu and two sticks of ram, one 256meg and one 512 both ddr400 budget ram..
Thnx Guys!
Httx3
HTT-260
vcore-1.55
ram voltage-2.5
Thnx Guys!
Have you found out exactly how high the FSB will go and still load windows? Try running a higher FSB and a smaller divider. That's houw I was able to boot 2.81ghz on Air cooling.
HTT: 3x
FSB: 296mhz
multi: 9.5x
1.33 ram divider
1.60 Vcore.
Try that.
I agree with sleepy916, a good PS is often overlooked and required for a stable OC!
Your MB may have hit the wall but the PS upgrade is still a very good investment.
The 3200+ venice isn't a great overlocker. 2.6 is good. I kept mine at 2750 for about a week and couldn't keep it stable. I think it's fried, I can't even go past 2500 any more.
Edit: My temps were only at 42c load too.
Discussion Starter · #8 ·
Oh dam that sucks, i'm getting watercooling soon as well so that along with new ram and a new psu should fix it i hope. My ram doesn't like going over it's stock voltage either so i think that could be a limiting factor as well. The max temp i get to is 38c at the moment.
Thnx alot guys.
1 - 9 of 9 Posts
