1 - 10 of 10 Posts
32bit OSes are for someone who has 3gb or less RAM, because it doesn't recognize anymore than that.
64bit is for someone that has 4+gb of RAM. it recognizes it and can use it to its full potential.
so it doesn't matter for OCing.
I'm new here but WHY????
Shouldn't it not matter? I always thought that the CPU speed was more low level than the OS and was independent of the OS. I don't doubt real world performance but theoretically shouldn't it be the exact same? Unless I'm missing something here like memory addressing or some weird concept that somehow magically affects it.
i9-12900K
Overclocking what?
CPU, it won't make any difference..
but GPU might have some issues with the different OSs Im not sure.
Executing 64 bit instructions would logically utilize more of the circuits in the CPU, thus, more power consumption and more heat. So it would be logical that a CPU could over-clock higher if it has been "dampened" by only having to execute 32 bit instructions.
I think the more important question would be: Is a modern 3.5GHZ machine limited to 32 bit instructions going to perform better than a 3.4GHZ 64 bit enabled machine?
Being able to take advantage of 64 bit instructions will translate to better computing performance than a slightly higher clock.
Having access to more RAM can provide far better computing performance in situations that can utilize it than a slightly higher clock.
Eric
1 - 10 of 10 Posts
