1 - 16 of 16 Posts
Hi all
Reasonably new to the OC game.
I am having issues with my OC (4.4ghz at 1.336v) crashing when i shut down and sometimes when idling.
I should note that this doesn't happen all the time, nor on every shut down.
I suspect it has something to do with using offset mode but im not sure.
3570k chip
ASUS P8Z77 board
850w seasonic PSU
16gb ram (have tested with memtest86)
Let me know what additional details you need and i will post them up.
Thanks
Do you have auto tuner on? That is the exact voltage it gave me for my 3770k before I knew to turn it off....
If so, turn it off, and manually set voltage and multiplier. Do a gradual climb in both and go from there. 1.336 seems pretty high for that clock.
Not new to Overclock.net
You can either disable C3 and C6, or use a lower Load-Line Calibration setting and then raise the Offset setting in order to compensate for the extra vDroop. I would lower the Load-Line Calibration setting because it will result in a cooler Voltage Regulator Module, and you get to keep C3 and C6 enabled.
Reactions: Binkz
Originally Posted by Binkz View Post
C3 and C6 are both disabled.
I shall try lower the LLC from High to medium and adjust the offset.
Thanks two cables.
If C3 and C6 are disabled, then it's unlikely lowering the LLC setting will help. It may be that your offset is too low resulting in an idle voltage that's so low that even having C3 and C6 disabled doesn't help. So I don't know, I think raising the offset a bit might help.
Hmm any other suggestions if C3 and C6 are disabled with .045 offset?
Im still getting crashes on shutdown and sometimes while idling.
Medium LLC setting.
did u try disabling package c state? it fixed my problems anyway.
Discussion Starter · #14 ·
Went to test the new settings on prime95 - no bluescreen but enough whea loggers to sink a battleship and prime95 crashed after about an hour..
FINALLY have it stable at approx 1.336v (sometimes goes to 1.344 but mostly 1.336).
Unsure what exactly i did though as ive had it at this voltage before.
Just ran 10hours of prime with no issues, temps 80c max.
I think increasing the LLC to High has helped.
Thanks all for your help.
What a mission.
Discussion Starter · #16 ·
ugh still has random shut down errors.
overclock high voltage is stable and gpu overclock is stable.
low voltage is like 1.08v min with all the C1 C3 etc turned off.
farkkkkkkkkk
1 - 16 of 16 Posts
