21 - 28 of 28 Posts
when you loosen timings and lower frequency, you have to raise the voltage on RAM? <img alt="" class="inlineimg" src="/images/smilies/confused.gif" style="border:0px solid;" title="Confused">
Well, not entirely. I think it depends on which RAM you have. I have my RAM running on a 133 divider, but it boots up at 440mhz, and I'vejust recently tightened my timings to 2.5-3-3-7-1T... Sorry for the confusion, was just trying to help him think of possibilities...
Discussion Starter #24
<div>Originally Posted by <strong>3xtr3m3</strong></div>
<div style="font-style:italic;">How long did it run the Prime ?<br><br>
And did you try to run your rams at 1T (Dual channel)</div>
</td>
</tr></table></div>
I cant it wont boot when I do <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown">
What did you do to consider it stable? Prime95 for 8 hours? Superpi32M? What? <br />
<br />
With a DFI board the three keys to stability are as follows:<br />
<br />
Memory settings<br />
<br />
In that order.<br />
<br />
You need to post what kind of ram modules you're using, what chips that are used on those modules and then post ALL of your ram BIOS settings.
Discussion Starter #26
<tr>
<div>
Originally Posted by <strong>Ihatethedukes</strong>
</div>
<div style="font-style:italic">Wow, what a bunch of amateurs. What did you do to consider it stable? Prime95 for 8 hours? Superpi32M? What? <br />
<br />
<br />
<br />
<br />
You need to post what kind of ram modules you're using, what chips that are used on those modules and then post ALL of your ram BIOS settings.</div>
</td>
</tr>
</table>
</div>Its primed for 24hours <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
<br />
If you look at the first post it says the ram I have in the CPU-Z validation and it shows the ram.<br />
<br />
They are just 2 cheap 1s I ma using until I get my XMS back <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" />
First off, I've seen about two pages of absolute garbage in this thread. The best I've seen is a "more aggresive divider," Toad's post and the rest is a bunch of blathering rather than really asking what needs to be asked to help this guy.<br />
<br />
I need to know all of your BIOS settings for the ram to help you and in truth, it's wild ass guesses until you do.<br />
<br />
Unfortunately, you have to boot, go into the BIOS and write them all down then copy over. There might be other ways to get SOME of the settings but I've yet to see all them from an in windows program. A64 tweaker seems to be the best right now for that.
Filthy Casual
Well if it isn't the 3 GHz 3700+ club...
21 - 28 of 28 Posts
