It's a great core. you can do 2.75Ghz no problem and with good colling you can push 3.0Ghz on the right V.core
Originally Posted by Edge On other forums, there have been some instances of people trying to enable the second core on the other 3700+ Sandy. No one has been able to do it. It would be cool if it were possible. |
Originally Posted by sccr64472 If you take off the heatspreader, it'd end the mystery. I'm fairly sure it can't be though because they're being sold as a San Diego core. If that is not what's being received, then you were misled and that's not legal. |
Recently i ordered a ADA3500CGBOX , AMD 64 AHTLON , I ordered it off a website called NEWEGG, the processor is advertised on as being the "VENICE" core, 939, 512kb cache. I recieved it and it registers as a "MANCHESTER" core(CPUID)(CPUZ).? My understanding is that the "VENICE" core is a better core and it was my belief that the "MANCHESTER" was a cheapier core designed for inexpensive X2 processors. Im confused, I didn't know that the "MANCHESTER" was used for non X2 processors, and why alot of distrubitors are advertising this model number(ADA3500CGBOX) as a "VENICE" core if it's clearly not. Thanks in advance for your help. |
The Processors with an OPN that got the CG surfix are Manchesters Rev. BH-E4 and the ones with a CF surfix are Toledos Rev. JH-E6, in both cases an entire Core is disable. Because Manchester and Toledo are two Venices and two San Diegos in the same piece of silicon respectively, if you disable an entire Core from these, then you get the same performance than a Venice or San Diego with the same specifications. |
Originally Posted by RocKerClocKer but I'm skeered ![]() |
