1 - 7 of 7 Posts
I have 2 3700+ Sandy's at the moment and I was wondering which one will OC higher (assuming identical conditions). Basically, which stepping is better. I have the one in my rig now, KAB2E, and a new one, KACAE. Any ideas or links to some stepping sites?
Look here also it's a OC and Stepping data-base...It should answer most of your questions..<please link on site resources before linking off site ones> <b>EDIT:</b> Will do!!! Didn't think it would matter since it's just a data-base....
OCN Dinosaurian Member
This should help you out.<br><br><a href="http://www.overclock.net/faqs/101138-info-what-different-3700-san-diego.html" target="_blank">http://www.overclock.net/faqs/101138...san-diego.html</a>
Discussion Starter #4
Thanks guys! Quick responses too <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
SNERP!!!
You're going to have to see which one will take you farther. While you can get a general idea by the stepping, you cannot make a decision by just that. Every chip is different and stepping is just a general guide.
What was your full stepping?<br><br>
Mine is:<br><br>
KACAE 0604GPDW
1 - 7 of 7 Posts
