1 - 20 of 32 Posts
hey guys,need to know somethink ,i need ur help getting mine past or to 3 Ghz ,but i cant now i got 100 to spend for new parts and i dont know what to do my mobo is crap [no volt/vcore options] and got sock cooling<br>
asus a8v-e deluxe<br>
1gb kingston<br>
raptor74<br>
3700<br><br>
thx for ur time
what are your specs now
you probably just need a better Mobo with better voltage options so you can raise them and get your processor steady at around 3.0ghz <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br>
i have the same problem as you but im happy at 2.5ghz
Get a DFI. They will help you to overclock like no tomorrow. But be carefull you need to know what your doing with a DFI<br><br>
Non SLI (but can be modded to SLI): <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813136152" target="_blank">http://www.newegg.com/Product/Produc...82E16813136152</a><br>
SLI: <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813136151" target="_blank">http://www.newegg.com/Product/Produc...82E16813136151</a><br><br>
EDIT: If you get one you will need a new psu. 430w wont cut it.
Discussion Starter #5
is there a dfi for < 100$?<br>
also the specs u see are the specs i got<br><br>
keep in mind i need a cooler
Discussion Starter #6
<div>Originally Posted by <strong>PROBN4LYFE</strong></div>
<div style="font-style:italic;">what are your specs now</div>
</td>
</tr></table></div>
lol WHAT ARE UR SPECS cpu that is what is tba?????????????
lol. chill
Discussion Starter #8
ok fine il get <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813136152" target="_blank">http://www.newegg.com/Product/Produc...82E16813136152</a><br>
and an artic cooler freezer 64™<br>
i dont have enough for high quality ram all i got is kinkston™<br>
and my psu kicks @$$ its a cooler master<br>
supporting a 7800gt®™ 4HDDs and a burner ,wow man u cant go wrong
Link is broken, Your psu will not cut it for overclocking Coolermaster arnt good, If you have crappy ram just run a low divider like 7/10 (140)<br><br>
I would get a new mobo + PSU + save up for a better fan<br><br>
But get the links fixed and I will see how its looking <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
Discussion Starter #10
sry bout that <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813136152" target="_blank">http://www.newegg.com/Product/Produc...82E16813136152</a><br>
and no cuz i can just unplug sevral drives as ez as i can buy a new psu
<div>Originally Posted by <strong>vtech1</strong></div>
<div style="font-style:italic;">ok fine il get <a href="http://www.newegg.com/Product/Produc...82E16813136152" target="_blank">http://www.newegg.com/Product/Produc...82E16813136152</a><br>
and an artic cooler freezer 64â„¢<br>
i dont have enough for high quality ram all i got is kinkstonâ„¢<br>
supporting a 7800gt®™ 4HDDs and a burner ,wow man u cant go wrong</div>
</td>
</tr></table></div>
I had a faulty x2 4800...so I got a 3000+ venice for my MSI and now I'm running my 3200 Venice again...LOL at...<br><a href="http://valid.x86-secret.com/show_oc.php?id=128813" target="_blank">http://valid.x86-secret.com/show_oc.php?id=128813</a>
No No No No No.<br><br>
I am having to upgrade mine because my 480w Enermax cannot handle this DFI. DFI require a min of <b>b480w</b>.
Discussion Starter #13
<div style="font-style:italic;">I had a faulty x2 4800...so I got a 3000+ venice for my MSI and now I'm running my 3200 Venice again...LOL at...<br><a href="http://valid.x86-secret.com/show_oc.php?id=128813" target="_blank">http://valid.x86-secret.com/show_oc.php?id=128813</a></div>
</td>
</tr></table></div>
hey man this is realy good and as i said i only got 126 MAX if the board costs 104 leaves me with .......i can try to get a little more but im pressing my luck my mom wont give me money for free
<div style="font-style:italic;">hey man this is realy good and as i said i only got 126 MAX if the board costs 104 leaves me with .......i can try to get a little more but im pressing my luck my mom wont give me money for free</div>
</td>
</tr></table></div>
What Bios are you using? it's possible there my be a modded one out that'll help with the voltages and stuff...let me get a look see<img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
Discussion Starter #15
uh ok thx but idk ,all i know is u can go to <a href="http://support.asus.com/download/download.aspx?SLanguage=en-usand" target="_blank">http://support.asus.com/download/dow...guage=en-usand</a> and ul see i think i updated it<br>
all i know is it A8V-E Deluxe BIOS 1012<br>
Support new CPUs<br><br>
EDIT: why dont u IM me my aim is vforce1
Hello,<br><br>
What model are your Kingston Modules? Are they the Kington VAlue or Hyper-X?<br><br><img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
Discussion Starter #17
<div>Originally Posted by <strong>MjrTom</strong></div>
<div style="font-style:italic;">Hello,<br><br>
What model are your Kingston Modules? Are they the Kington VAlue or Hyper-X?<br><br><img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"></div>
</td>
</tr></table></div>
well the stick cost me 158 about a year ago :kingston P/N k S/N 693281d4 pc3200 week30year00
<div style="font-style:italic;">well the stick cost me 158 about a year ago :kingston P/N k S/N 693281d4 pc3200 week30year00</div>
</td>
</tr></table></div>
Ah it is a single 1gb stick not 2x512 then?<br><br>
JUst wanted to check if you had the same modules as me, mine require loads of voltage to run at stock timings andcould have had an effect on your results. But never mind <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
Discussion Starter #19
yup
Discussion Starter #20
ok i fount the bios info<br><a href="http://assets.overclock.net.s3.amazonaws.com/a/a6/a6cfb852_vbattach60071.jpeg"><img alt="LL" src="http://cdn.overclock.net/a/a6/525x525px-LL-a6cfb852_vbattach60071.jpeg" style="width:525px;height:370px;"></a>
1 - 20 of 32 Posts
