1 - 2 of 2 Posts
Hi
I have OC on my CPU (4.3Ghz), with 1.35Vcore (+ offset) and C-State enabled.
However, in idle, the frequency and voltage do not drop.
I have the power plan set to 10% of the minimum processor state.
Can you help?
My board is Asus x570-I.
That Voltage is very high for ryzen 3000 CPU. There has been results of degredation from 1.3v
I would suggest putting it back to stock and running prime95 to find your FIT voltage and going to OC from there.
In regards to your question if you have set a fixed voltage and overclock it wont drop.
1 - 2 of 2 Posts
