1 - 3 of 3 Posts
Seems this is as high as my Corsair Value will allow, but can somebody give some advice on making this stable? I use 3DMark05/SuperPI/FEAR for stability tests btw, as i believe it's probably the best way to punish a system for stability.<br />
<br />
<a href="http://uk.geocities.com/m_hill2029/Help2.8.jpg" target="_blank">http://uk.geocities.com/m_hill2029/Help2.8.jpg</a>
OCCT, and Prime95. It's not really considered "rock stable" unless it passes the 8 hour Blend test on Prime95.<br />
<br />
All of my unstable overclocks ran games/benchmarks fine. But they failed within 5 minutes of Prime95.<br />
<br />
OCCT only takes 30 minutes, but Prime95 is argueably better.<br />
<br />
<a href="http://www.mersenne.org/freesoft.htm" target="_blank">http://www.mersenne.org/freesoft.htm</a>
Lower your multi so your HT is under 1000mhz. That'll help. You might lose bandwidth, but at least you'll be stable. I'm not sure that your ram can do that kind of FSB, we'll see.
1 - 3 of 3 Posts
