3d xbox ; )
473 Views 11 Replies 7 Participants Last post by  s0d0mg0m0rrah
check it out! not quite finished... lol. but getting there! not bad ehh?
and suggestions?
1 - 12 of 12 Posts
Apply a bit of mesh smooth or some thing similar to the ring (on/off button), other wise
after some more detail...
Cant figure out how to smooth out the button. My mesh isnt exactly organized... so mesh smooth really destroys it. Any ideas?
lol sorryy... I tend to forget about the vintage XBOX
You need to set the smoothing groups. If it still just makes a mess w/ m.s. or equivalent (not sure what app. you're using here) then unfortunately, you just need to make a cleaner mesh.
edit: Oh yeah, & lol @ "vintage".
Atari is vintage.
Atari is vintage.
3ds max
lol maybe origonal xbox is next : ). I just discovered Graphite modeling tools. After I made the orrigonal mesh.
. I had used a boolean before to get the ring indent... I didnt notice i was using a low poly sphere. oh well... Teaching yourself has its downsides... either way its cool
Originally Posted by phonyphonecall
3ds max
Don't worry about it. On something this simple, the graphite tools wouldn't have saved you a whole lot of time anyway.
Using a low poly sphere is fine, & the way you should do it. Uneccessary polygons are uneccessary.
You just have to set the smoothing groups &/or put in some chamfers prior to using sub'd / turbosmooth.
If you wanted to get really crafty, you can make that indent from a normal map, in fact, that's an ideal situation for normal mapping.
lol... idk what normal mapping is. im gonna see if i can work in a few chamfers
just recut some line and keep the mesh clean as said before and u can smooth it better
nice work man.. keep it up! teaching yourself is imho the way to go.. i mean mess around with different things.. and you can find a butt-load of free tutorials online! i'm currently doin a degree in in games design majoring in 3d and level design.. and i guess it's helped, obviously in theory but most things i've learnt at home in my own time. if you need any help or want any advice drop me a line sometime.
take care
1 - 12 of 12 Posts
