1 - 6 of 6 Posts
Hey guys,
I am just noticing that 3D Mark 11 is reporting my ram speed at 667mhz. That can't be right. If I look under CPU-Z it says my ram is running at 820mhz, which would be 1640. That is what it should be running at. I have my CPU set to 205x19.5 and the FSB:DRAM ratio 1:4, timings are 9-9-9-24-41 1T.
Is this a normal bug with 3D Mark or is my RAM actually running at that speed? I am terribly confused lol, and I am trying to figure out how to get my physics score higher. Not sure if it's because I don't have a PhysX compatiable GPU, or what.
Super Moderator
Reactions: vitalsine
Thanks broheim. It was trying to update earlier but kept giving me problems. Looks like that worked, had no idea that was what was causing the issue!
Super Moderator
Not problem
Discussion Starter #5
Off subject, but I see you also run a HAF 932 in your AMD rig. Any advice on water cooling? I was looking at an XSPC kit and a EK kit. I am looking at mounting the rad on top where they have the mounting holes and then using the fillport for my res. What kind of cooling are you running?
Super Moderator
I'm running a HAF X that's more big than yours. Any way, I have a 3x120 radiator on top and the reservoir next to the PSU because exist a big space there. Check the attachment picture.
IMG_20120505_194637.jpg 505k .jpg file
1 - 6 of 6 Posts
