1 - 8 of 8 Posts
Hi,
Did you have a difference between the two versions.
With 1609 5308
With 1803 5200
Why are performances worse ?
9 Cans of Ravioli
Nothing's changed here. I'm still putting in normal 3DMark numbers on HWBOT.
Overclocker in training
Hi,
You skipped 1703 and 1709 win-10 versions :)
Mostly I suppose meltdown and spectre but all it all 3Dark in general has gone pretty much down hill too in the last several version updates.
Also NVidia drivers have be less than helpful too for way too long newest one seems okay for benchmarking but I have not used it to game.
Even more spectre issues found,
Looks like i'll be getting a 2700x soon
Exclusive: Spectre-NG - Multiple new Intel CPU flaws revealed, several serious
https://www.heise.de/ct/artikel/Exc...U-flaws-revealed-several-serious-4040648.html
Hi,
Sure for one use rig builder and add your hardware to it and added it to your signature area.
There are multiple 3DMard benchmarks which one are you referring to exactly and which exact version paid or free.
Are you using a local account now called "offline" user account or a MS account.
Jumping from 1609 to 1803 you'd probably need to clean install 1803.
Totally Tubular
Make sure the graphics driver settings are all the same as they were.
Sometimes newer drivers are slower than older drivers. Try using a previous driver version.
1 - 8 of 8 Posts
