4.0 Ghz e7200 on air cooling
3222 72
WOOT after working on my overclock for a while i finally hit 4.0 stable on air cooling.
I can post pictures of my setup when i get home
who else has gotten this proc to 4.0 on air?
1 - 20 of 73 Posts
Congrats on this overclocking!
The highest speed I have reached with this CPU is 3.515MHz stable using my Thermaltake TMG i1 air CPU cooler.
Stress Testing with Prime95 my temps got to 65°C (Real Temp) on both cores.
How did you stress test your system?
What are your temps during stress test?
Have you tested using OCCT 3.0 (it now has the Linpack test, which is the same as IntelBurnTest)
i had it at 4GHz on stock cooler before!!not stable though
as of now i have it at 4.1GHz stable @1.36vcore considering the vdroop!
If you haven't used the OCCT linpack test or Intelburntest previously at this speed, I will advise to be cautious.
Maybe you can run one OCCT "Normal CPU test" and see your temps using "Real Temp" or "Core Temp". If it is ok with the normal test, then try with the Linpack test. This Linpack test really tests your cooling...
Discussion Starter · #6 ·
Thanks for the heads up
what cooler are you using?
· Premium Member
I want to see a screenshot of 12+ hours of Prime95. Then the 4 ghz overclock will be more believable.
Originally Posted by poyyiee View Post
does anyone try,wit stock hsf, how high OC e7200 can go??
The highest I could get my E7200 with Intel's stock fan was 3.24 GHz (340 x 9.5) with 1.312V Vcore. Core temps during stress test got to 71°C & 70°C, as reported by Speedfan, which I know now is reporting about 5°C higher than RealTemp.
I tested it stable with 6h Prime95, 2h OCCT, 14h Memtest86+.
ooo,nice1..
but,70,71c is still within safe temp range for 24/7 proc, right???
Discussion Starter · #18 ·
since you are the only one that doesn't believe me i will get one for you then
got my e7200 and try OC it, but currently got to 2.66Ghz..huhu,mehhh
but, more weird thing is, CPUz keep showing my cpu multiplier change between 9.5x and 6x..WTH is going on??
mybe cause by my old mobo???mobo gigabyte945GCMX-s2..
any idea y???
1 - 20 of 73 Posts
