1 - 5 of 5 Posts
Hey guys,
I'm @ 4.5ghz stock voltage. HEre's my specs
Gigabyte UD7
Corsair Vengance DDR3 @ 1600mhz
NOctura DH14 cooler
I've ran prime95 and stressed the cpu gets to 49C idle around 23C.
So far I still have the regular stock shipping bios. if I put the mulitplyer @ 50X it boots but won't load windows same thing at 48x. Wonder any suggestions that you can give is there a multipler problem with the default bios etc? shold I bump pll voltage up a bit and try?
http://valid.canardpc.com/show_oc.php?id=1591846
Thanks
I'm idling at around 30C. What cooler you using? And what voltage?
As far as your issue goes, have you messed with any of the power saving features?
Originally Posted by joey2162
4.5 stable @ those temps isnt enough?, thats amazing , leave it alone
CPU-Z is reporting the wrong voltage. That's his Vtt voltage. CPU-Z 1.56.2 fixes that issue with Gigabyte boards.
1 - 5 of 5 Posts
