OK so im oc my fx 8320 and so far im at 4.6ghz on stock volts. How is this possible? Most of the forums i go to they atleast had to bump up the volts a little bit and are getting hight temps. Im using AIDA64 and speed fans to record my temps and the highest ive gotten on both was 54c on full load. Did i get a really good cpu for oc or am i do something wrong? i notice i do get a bit more stuttery at 4.6 at full load but i assume thats because my voltage is drooping. core voltage 1.356 multiplier 20 htt clock 230. i am doing this way of oc because i was hoping to make my ram faster as well. thanks for the help in advance, cheers.
specs:
FX 8320
ASUS M5A99FX PRO R2.0
Cooler Master hyper 212 plus (dual fan)
8gb G.SKILL ripjaw 1866mhz
ASUS hd 7790 direct cu2 2gb
650w bronze thermaltake psu
2tb wd green
specs:
FX 8320
2tb wd green
