1 - 17 of 17 Posts
I have a 64 bit OS, any reason why my pc wont show all 4 gigs of memory?
Im going to start check the sticks one by one i guess.Hopefully one isnt bad?
It only shows 3.25.
Photo attached.
Thanks.
Your motherboard needs to perform memory remapping or hoisting.
Reactions: Twinnuke
I have a 32 bit operating system and it shows 3.25 gigs.
Type in msconfig. Right click the msconfig app to run it as Administrator. That brings up the configuration utility. There is a setting for Max Memory - Make sure that's unchecked/blank.
This
50% of the time it works every time
you can change it in your bios usually under memory options or such...
Reactions: Murderous Moppet
Discussion Starter #5
Ok thanks for the leads all.
Is it possible also because I have XP installed on a secondary drive? I wouldnt think that should matter since im in vista right?
Has nothing to do with it.
I remember, my dad's OEM Acer computer had a setting in the BIOS that stated what amount of memory [2.5GB, 3GB, 3.25GB etc.] to map; while this feature is for 32-bit systems, it might also affect 64-bit systems. However, my dad's comp uses 32-bit Vista [Basic] and 3GB of RAM so that setting is irrelevant for me.
Try finding it in your BIOS and setting as necessary.
LOL everyone knows 32 bit will not utilize all 4G
Not everyone
Go into MSCONFIG goto boot and click advanced boot options and theres a option for memory
Originally Posted by theintrepidmontti
This
"i'm going to be honest with you, that smells like pure gasoline"
Borking Builds Since 2020
Psst, recheck his attachment in the OP, he's got a 64-bit OS
"Oh God, it smells like a used diaper full of Indian food!"
Oh man, what a great movie.
Anyways... A friend of mine bought a <shudders> eMachine from.. <shudders again> Best Buy recently. It has 4gb of ram, but shows 3.75gb. This is on a 64bit Win7 install. I spent hours trying to fix this with no avail.
Don't strangle me! I know this is one of the greatest offenses to us techies, to #1 - go th Best Buy, and #2 - tell someone to get an eMachine.
In defense.. The guy was broke and used credit to buy it. I tried everything in my power to make him build a machine with me.
1 - 17 of 17 Posts
