1 - 14 of 14 Posts
is it possible to have Raid 0 with 4 HDDs on P5W DH mobo??<br />
i know there are 3 connectors at the bottom right hand corner and one black one by the CPU and 2 orange connectors<br />
the problem is only the first 3 SATA ports are controlled by ICH7. there fore is it eve possible to have 4 HDDs raid 0??<br />
<br />
<br />
thnx
No idea.<br />
<br />
Did you read the manual?<br />
<br />
If you can to a cross-controller RAID, it's probably explained in the manual.
<tr>
<div>
Originally Posted by <strong>Chozart</strong>
</div>
<div style="font-style:italic">No idea.<br />
<br />
<br />
If you can to a cross-controller RAID, it's probably explained in the manual.</div>
</td>
</tr>
</table>
</div>cross raid is only possible for raid 10
Guess not<br />
<br />
<div align="left"><b>Intel ICH7R South Bridge:</b><br />
*1 x UltraDMA 100/66/33 <br />
*3 x Serial ATA 3.0Gb/s with Intel® Matrix Storage Technology with RAID 0, 1, 5 support<br />
<b>Jmicron JMB363 controller</b><br />
*1 x UltraDMA 133/100/66<br />
*1 x External Serial ATA 3.0Gb/s (ASUS SATA-on-the-Go) and 1 x Serial ATA 3.0Gb/s with RAID 0, 1, JBOD support<br />
<b>Silicon Image 4723 Hardware RAID controller (ASUS EZ-Backup)</b><br />
*2 x Serial ATA 3.0Gb/s with RAID 0, 1 support<br />
*Support RAID 10 cross Intel® ICH7R and Silicon Image 4723 controller</div>
Discussion Starter #5
<tr>
<div>
Originally Posted by <strong>Mikey122687</strong>
</div>
<div style="font-style:italic">Guess not<br />
<br />
*Support RAID 10 cross Intel® ICH7R and Silicon Image 4723 controller</div></div>
</td>
</tr>
</table>
</div>damn that sucks<br />
i guess i need to buy controller card then
Discussion Starter #6
<tr>
<div>
</div>
<br />
</td>
</tr>
</table>
</div>actuall it works!!!!
<tr>
<div>
Originally Posted by <strong>hanwinting</strong>
</div>
<div style="font-style:italic">actuall it works!!!!</div>
</td>
</tr>
</table>
</div>Lol gj, looks like you don't have to sell it after all.<br />
<br />
I know there are 4 SATA slots but i don't know if you can combine the 2 RAID driver to 1
Discussion Starter #8
<tr>
<div>
</div>
<div style="font-style:italic">Lol gj, looks like you don't have to sell it after all.<br />
<br />
I know there are 4 SATA slots but i don't know if you can combine the 2 RAID driver to 1</div>
</td>
</tr>
</table>
</div>i use the fourth one from the EZ connector <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> its really fast !
The 4th SATA is from a different controller, I wouldn't recommend using that if you're able to or the mobo allows it. That is the reason why I didn't go with the P5W-DH Deluxe and the P5B Deluxe has 6 SATA ports supported by the south-bridge, so no need for a different controller, whic is not a good idea IMO.
<tr>
<div>
Originally Posted by <strong>Nasgul</strong>
</div>
<div style="font-style:italic">The 4th SATA is from a different controller, I wouldn't recommend using that if you're able to or the mobo allows it. That is the reason why I didn't go with the P5W-DH Deluxe and the P5B Deluxe has 6 SATA ports supported by the south-bridge, so no need for a different controller, whic is not a good idea IMO.</div>
</td>
</tr>
</table>
</div>Whats what i said earlier. I know there are 4 SATA connectors but I know only 3 comes out of the ICH7R so i have no clue where he gets the fourth one
Discussion Starter #11
<tr>
<div>
</div>
</td>
</tr>
</table>
</div>any reason why u said its not good??
<tr>
<div>
</div>
<div style="font-style:italic">any reason why u said its not good??</div>
</td>
</tr>
</table>
</div>Because the 3 SATA that came out of the SB are ICH7R and the last one is not, its Jmicron, so its not wise to mix and match here
<tr>
<div>
</div>
</td>
</tr>
</table>
</div>Just like Mikey says and also the ICH7-R is by far way better than any 3rd party controller performance wise. <br />
<br />
But RAID 0 with only two drives should be enough though, I have 5 HDDs but only two are in RAID while the other 3 are the same 250GB, I don't see a point in having 4x HDDs in RAID 0 unless they were 40GB each.
1 - 14 of 14 Posts
