1 - 20 of 32 Posts
Ok guy's, I went a little overboard.... I purchased 2X 680 Classified's.... So i will need to run 4X EVGA GTX 680 Classified cards in SLI.
I need a 1155 board that supports four of these and my Xonar STX...
I am thinking of this, as it might have room.....
ASRock Z77 Extreme9
Thoughts?
Thanks!
· Premium Member
G1 Sniper 3 if you're looking for the best value.
Other boards that support it:
P8Z77-V Premium
Maximus V Extreme
GA-Z77X-UP7
That ASRock and Extreme11
ECS board in the same price range as G1 Sniper 3.
· Premium Member
Asrock Extreme 9 also a very good choice
But I would go for this
Asus Maximus V Extreme
Discussion Starter · #6 ·
P8Z77-V Premium
Maximus V Extreme
GA-Z77X-UP7
See above, ha.
· Premium Member
You'll need some kind of PCI-E x1 extension like this.
All 4-way SLI boards have pretty much the same layout. You'll need that ribbon cable with any of them, or just buy an external DAC.
· Premium Member
You can always use a PCIE Extender.
(Edit: above user got ahead of me
Discussion Starter · #12 ·
Ok,
What board that does 4 way sli has the best sound ?
Looking to run some nice headphones off of it.
At this point I need to consider ditching the sound card.
· Premium Member
Asus Maximus V extreme
7.1 Surround
One of the best On-Board chip/codec
I have the same Chip on my Rampage IV Extreme and it does a pretty nice job with my M-Audio AV40
· Banned
MVE's can blow and take CPU with it.. heard lots of horror stories in the bench sections regarding this..
Personally I would take the G1.. cant beat it for the price.. its got all the right ingredients for a nice build, and doesnt carry the premium $$.
· Premium Member
Proof?
· Premium Member
This is ONLY when under sub-zero. For normal users it is brilliant.
· Premium Member
G1 probably got the best out of bunch. It's Creative codec, but still no where near STX.
· Premium Member
Great choice
1 - 20 of 32 Posts
