1 - 6 of 6 Posts
I recently upgraded my two rigs. My second rig got my 3700+ san diego and I bought a new 4000+ san diego for my main system. In another post discussion about motherboards I was told that the two chips would have identical performance regardless of the fact that the 4000+ has a 12x multiplier and the 3700+ a 11x. Is this true? I can't accurately bench the differences as my two systems have different video cards, motherboards and ram. My rig two is 3700+, asus A8N-SLI Premium, Gigabyte 6600GT (I had two in SLI but sold one of them, don't really need it for this system), 2 x 512 MB Enhanced Latency Platinum OCZ RAM, and a 36 GB Raptor.
I got a really good deal on the 4000+ (It only ended up costing me a few bucks more than a 3700+ would have) but it would be frustrating to find out that the new chip doesn't give more bang than the old one.
Thanks
You could run CPU intensive benchmarks and compare. Run Aquamark3 and it should give you a CPU score as well as a graphics card score. If one is higher than the other than you'll have your answer.
At stock, the 4000+ would obviously be faster. However, the average 3700+ and 4000+ will overclock the same as the only difference between the 2 cores is the extra multi.
Still, if you got a good deal on it then nothing lost really
The extra multiplier doesn't mean extra performance, it just means extra flexibility with overclocking and memory speeds.
I would still say the 4000+ has a better chance of hitting higher speeds..
No, it does mean better performance, in that the 4000+ comes out of the box clocked 200MHz higher than the 3700+.
1 - 6 of 6 Posts
