1 - 20 of 41 Posts
Originally Posted by madgamer
what is the diff. between the amd 4000+ and fx-53 and which is better?
I heard they perform almost exactly the same. Any amd guys know?
FX-53 is based off the SledgeHammer core used in Opterons and has the full range of multipliers unlocked. The 4000+ is based off the ClawHammer core formally used on Socket 754 (and retrofited to use dual channel memory) but has the upper range of multipliers locked. Both run at 2.4GHz, have 1MB of L2 Cache, and run Dual Channel DDR400 memory.
I think it's the other way around Yiffy... FX-53 is Clawhammer and 4000+ is Sledgehammer.
No, that wouldn't make any sense. The FX-51 was literlly just an Opteron 250 rapacked for use on the desktop market and they have continued to use SledgeHammer in FX series. The 4000 uses a dual-channel memory varient of ClawHammer called ClawHammer-S.
Yeah ur right, Newegg n00bed out and mixed up there cores.
I'm still not positive... I've seen CPU-Z screen shots showing FX-53s as both ClawHammer and one showing it as SledgeHammer. I'm half-tempted to email AMD and just get it out of the way...
Actually you should do that, since u've seen screenies showing both cores.... Perhaps the early model FX-53's were Clawhammers and they have switched them to Sledgehammers?
I would think the other way around, but possibly. I know the Socket 940 53 are SledgeHammer for sure though, all 940s are SledgeHammer
Errrr yeah vice-versa... Maybe they found one core to be more efficient / effective than the other. I've been seriously tinkering around with the idea of buying an FX-55 or 4000+ and seeing how fast I could get it on air cooling.
I would... if I had an extra $800 lying around I didn't need
I was tinkering with the idea of selling one of my paintball guns to get an FX-55, new case, and an XP-120.
i had the same idea but i can't sell my paintball gun that would be sad
but it is tax return time $$$$
Damn. What kind of paintball gun do you have? like a bob long or somthing? lol. Intimidator?
1 - 20 of 41 Posts
