Originally Posted by -JeeOweDee-
I'm having problems with Orthos for 3ghz. It's failing the second after it starts. My vcore is going from 1.46 - 1.48. Does putting a divider on your RAM completely elimate the RAM from being the reason your OC isn't stable and/or won't clock higher?
Putting a divider on your RAM simply allows your HT ("FSB") to theoretically scale higher. I say theoretically because this is also dependent on whether or not you're hitting the limits of your motherboard's HT frequency. Assuming it's not, then it's a bit like selecting a higher gear on a car's transmission, if this makes sense. Imagine your engine (HT) is pulling 7000RPMs in fourth gear; if you change to a higher gear (or, a bigger RAM divider, which will result in a higher ratio between your HT and your RAM frequencies), this drops your engine's RPMs, but allows it the headroom to scale up in RPM again (and therefore push your car along faster). It's a similar principle at work.
When going just for raw CPU maximum speed (and therefore going using as much HT with the highest CPU multiplier combined), it pays to "upshift" to the lowest RAM frequency (a higher gear, or a bigger divider) you have available. Whether or not this is the best setting for performance is something that has to be tested, but it should allow for the maximum CPU speed.
Stability at these speeds, of course, is a total unknown and must be tested thoroughly.
Hope this helps!
