4670 x 2 upgrade under $150AUD
668 Views 10 Replies 5 Participants Last post by  Derp
I'm wanting to upgrade GPU's but not if there's any point as i can only afford $150 towards the card, thinking it be better spent on second 320GB for RAID and better PSU...
Thoughts
1 - 11 of 11 Posts
id increase your budget a little and get that
http://www.newegg.com/Product/Produc...82E16814102864
AUD means Australian dollars and Newegg doesn't shipp internationally.
@OP: Not much around the $150 mark that would better what you have now. Best bet is to save a bit more ($65AUD) dosh and buy the 5770 of your choice for best bang for buck.
Take a look at this place, I shop there A+ Service at the Milton store.
True but figured card was the point and that card i can get for $195(MSI,1GB) over here... Cool thought, if i held out for a couple of months then yeah but buy then I could buy a 58** for the same money.. BUT i'm impatiant
Flux, mate, that's my favourite store: value for money plus 11km from home, though Gamedude is only a 20min detour on the way home from work.
if not using umart - look at www.staticice.com.au - its a nice search engine for aussie etailers
A note - a 5770 = HD4890 + DX11 + less heat + less power
flux - come join the aussie club
I would avoid gamedude for GPU's and pretty much everything else. They tend to not have what have advertised. Save the fuel and swing past umart.
Already a member, just not about the thread much. Spare time is lacking with two twin boys.
Thanks though mate.
An HD5770 would be a waste of money, crossfired HD4670 is faster then a HD4850 and a single HD5770 is about equal to a HD4870 and in some cases even slower. This would give you a very minimal increase making it not worth it. Save your money and buy a better card so you will actually see a difference.
Generally find Umart cheapest and closest
Would overclocked 5750 come close to 5770? From what i can figure 4670's crossfired = 4870ish - XFX4870 for $190 local
not sure on the 5750 mate - havent seen anything on it myself
flux - sounds like fun - i wouldnt know - im just 18
Read some reviews, he is definitely wrong. HD4890 > HD5770, its not that close either.
http://www.tomshardware.com/reviews/...g,2473-15.html
1 - 11 of 11 Posts
