I have ocerclocked my i7-3960X on Asus RIVE to 4700MHz with VCore 1.6V. When I check AIDA64 it tells me the frequency is 4400MHz, 3DMark11 says the same. Any sugestions?
Whoa. Try 1.3 or so first. Don't let the auto tuner do the OC'ing. My 3770k was running at 4.5 Ghz at 1.36V because of Auto tuner. Now, I run at 1.24 stable.
Because the temps are well within limits and stable. And I have the probe enabled, so if it gets too hot it will shut down.
I can stick a wire with 10 megawatts going through your skull and it wouldn't get above room temperature. Tell me how good it would feel though.
Haha.
TURN DOWN YOUR VOLTAGE. I would not go over 1.45v 24/7.
This ^^!Originally Posted by driftingforlife
What cooling are you useing?, also get rid of AI suite. Do all the OCing in the BIOS.
http://rog.asus.com/forum/showthread.php?5836-ASUS-Rampage-IV-Extreme-Easy-Overclock-Guide&country=&status=
Are you asking for help or are you trying to defend yourself over your own thread...?
