1 - 19 of 19 Posts
PC Evangelist
Thats very good. What cooler are you using?
PC Gamer
Im seeing in your pic 85-86c on a couple cores. Which is a bit to rich for my blood. Sure it wont hit that high in anything else...but still a bit to much for my liking.
Looks good, but I probably wouldn't go any higher until you get better cooling. Compare with other's in the spreadsheet available in the Stable club
Vcore set to 1.22 and you're getting 1.35v? massive vrise, are you using Extreme LLC? take it down a notch and increase the vcore to 1.35v or thereabouts.
Just another nerd
Looks like a decent chip, about the same as the 2500K I helped my friend OC recently.
This, your processor is at the t-case temperature (72 C) right now. I wouldn't push farther until you can get cooler, but with decent cooling you should be able to get 5 GHz.
Not New to OCN
We must have pretty close chips. I can get 4.8 @1.34, highest I've gone is 5.25, not stable, but enough to do like super pi
. I paid $65 for my h50 and it keeps it nice and cool.
Looks like a pretty good chip as long as it stays stable.
OG AMD
NZXT Havik 140 is perfect for you ,comes with 2 decent fans,clearance for RAM slots,leaves VRM's open to air as well as actually blowing air over them the way the fans are situated.It's a lot narrower than the Noctua.
Looks like a good chip..I wouldn't push it higher until/unless you get better ccooling..like something along the lines of a raystorm block...
umm..you could disable 2 cores and get a little headroom if you want to see how high it will go.Possibly even max it and still stay under "deadly" temps
Discussion Starter · #19 ·
Okay I bought the Noctua NH-D14 SE2011 so that should tackle the temps.
Also I forgot to update my specs but I installed a Capstone 750w PSU right before I started overclocking.
1 - 19 of 19 Posts
