4850 Gods Of Overclock
1584 Views 23 Replies 13 Participants Last post by  skugpezz
And Now Ati Gamers are more than ever i think i have superclocked my card and it is already stable. gpu temp load : 62 C
Core Clock :780
Memory:1125(it also stable on 1150 but this is better)
I need GTX260 Competitor and gpu-z resualt is here
http://www.techpowerup.com/gpuz/cxscf/
whats your opinion?
1 - 20 of 24 Posts
Wait 24 hours before bumping your own thread.
I've seen higher OC's on the 4850.
solid 25% overclock.
pretty good temps, but i dont know much about the stock temps for that card.
whats your ambient?
PS: try to break my 34% overclock on the core
oh and your validation says your memory was at 1100 not 1125 or 1150. revalidate with those clocks.
NCspec had a 40%+ OC on his 4850
http://www.techpowerup.com/gpuz/va6w9/
The 4850 is just a downclocked (and probably lower binned) 4870 core, you should be able to hit 800mhz with voltmod and good cooling.
850Mhz/1200Mhz stable here 55C load. I can validate up to 950Mhz if you want.
what card do you have?
and what is it stable at in games?i can run ati tool without any problems at 750 but can't go over 730 while playing games.
Mine is Atitools and Crysis/CDO4/CSS/Far Cry 2 stable
nice to know but i was inquiring of the op.he wanted opinions and now ran off.
did you pencil mod or hard mod your card?
jeez man... that's high...
it musf fly at that speed...
Did you volt mod or used a custom Bios?
Pencil mod. 1.35 volts.
hi my brand is force 3d
can i use pencil mod?
where can i download it?
how can i update bios?
with GPU-Z you get the bios you have. Use the RBE to edit the bios and then use ATIwinflash to flash the card. If you clocks are 780Mhz then you dont benefit from bios flash.
Damn! Did you notice a significant FPS increase to that from stock?
1. 3dmark06 with Q6600 @ 3.6 i got 14k stock and then with OC 16.5k. Also in games like crysis i got enough fps increace to make very high playable which i could not to with stock. I will make one day a thread to comare the impact of high OC on GPU or ram.
Is there a guide for the pencil mod? Does it void your warranty?
1 - 20 of 24 Posts
