4850 X2 vs 5770
3378 Views 7 Replies 5 Participants Last post by  kow_ciller
Hey guys, last post about cards for awhile (i hope haha)
I was reading Toms Hardware and was reading about both. And After reading the articles for awhile, I came to the conclusion, that 4850x2 is faster than the 5770, but doesn't support dx11. If I don't care about dx11, is the 4850 worth the extra 50 bucks?
1 - 8 of 8 Posts
Nope..
5770 uses less power and the 4850 will produce more heat..
But besides heat...and just as far as gaming goes, what gives me a better performance?
I'd still prefer 5770, dx11 support and not all games support crossfire.
I didnt say I was going to crossfire the 4850x2 tho, I'm just wondering right now whats the best of the 2
@OP
To answer your question, the 4850 X2 is ~40% faster than the 5770. That being said, the 4850 X2 is getting "long in the tooth" ( a bit old), doesn't support DX11, and is 10-3/4" long. Both are good cards. Good luck with your decision.
If you want the performance now, the 4850x2 would be the thing to get. But you might want to go for a 4890 instead since they're extremely close (it would also use less power/ be cooler)
1 - 8 of 8 Posts
