1 - 6 of 6 Posts
i have a 550 watt psu and i want to attacht the 8 pin power cable to my video card.my other PSU is a 3500Watt and i would like to attach the 6 pin power cable from that to the 4850x2, but i ran into a problem the other PSU dosent turn on when the other one dose (duh). is there any way that i can get the other one to turn on without plugging into a mobo?
Just upgrade your PSU. If you are trying to power the video card with the 350w, i really doubt it would have enough amps for the video card. Generally running two PSU's like that Wouldn't be a very good idea. But if you have to, the 350w will have power when it's plugged into the wall, you don't need a motherboard to turn on a PSU.
It really all boils down to the rail amps, and a 350w powering a $300 card, I wouldn't trust or do that.
Discussion Starter · #6 ·
Originally Posted by kairi_zeroblade View Post
get something thats beetween 700 and 850..with efficient 12v rails..
oh jeez i NEVER though of that, ill just go grab a handfull of money form my giant pile and buy a new one.
Originally Posted by linskingdom View Post
4850x2 takes a bout 210w/220w from 12v alone plus the your processor and others so you need a solid psu. Is this for the Phenom 9950 BE rig? May need a 550w such as Corsair 550vx.
yes this is for my current rig, and i allready have a 550w PSU and its not enough.
im trying to power the video card half with a 350W psu and the rest with my 550W PSU. i have 19+19 amps from my current PSU and the 350Watt one has an extra 15 amps.
Originally Posted by mr.derp View Post
Well you could just use your 550watt to power it, if its a half decent power supply. You can power a psu without plugging it into the motherboard, it takes a paper clip to do so.
i am using my 550W to power my whole system and its not enough, i wanan turn the ****ty 350W PSU and use the 6 pin power cable from that for an extra 15 amps. and ya i need to power the 350W psu without pluigging it into a motherboard, any idea how?
1 - 6 of 6 Posts
