My main monitor is using the DVI input on the card and i just plugged my old 15 inch crt to use as a secondary monitor through the hdmi to dvi cord, then used the dvi to vga adapter to plug the monitor in, the lights blinking on my crt but it wont display a picture. I'm certain the monitor works so that isnt the issue. is it because im daisy-chaining so many different things?
