Problem: My system is 100 percent stable with the overclock either 4870 can handle every stress test furmark etc and temperatures are below normal at load but when it comes to dx10 tests it fails most of the time i am using it with def. clocks tried everything to fix it but its the same.Any idea what may cause this problem ?
okey thank you very much btw i thnk it started to happen after i instatted STALKER benchmark program(it installs directx 11 etc) and as far as i know my card doesnt support 11 so whats confusese me : dxdiag shows my version 11 thx
lol well its a fun game you have no idea try it sum time did reinstalling it fix the problem
Even Formatting, changing pci slot, changing hdds, changing cpu and other settings to def. didnt solve it but i ll try to downgrade drivers especially directx and report back ..
how hot is your mem i put costume heatsinks on ming it got to hot and crashed and make shour nuthing is shorting out your pcie card or the slot because you don't have a case
Yeah, those temps are fine. Nowhere near being an issue. I don't know what to tell you. If you have reinstalled windows and everything and it still isn't working, I just don't know. Maybe, if you have access, try putting it in a friend/family members computer and test it. Just to rule out any other hardware being the culprit.
5 th run in a row no problems with latest CCC and driver too if i come to a possible conclusion S.T.A.L.K.E.R benchmark causes these crashes(it installs various directx packages and dxdiag shows my dx version as 11)
Thank you all for helping very appreciated
Overclock.net
