1) Super Fetch is a service you actually want and people need to stop saying to disable it. Yes your harddisks will grind after a format for a couple of days (learning time) and during windows startup, but this is for a good cause. Super Fetch pre-loads programs (games w/e) you frequently use into your (un-used) memory. This is a good thing as it will shorten the load-times of your programs by a lot.
2) I wouldn't know anything about it, but sounds plausible.
Will give it a go later, when I'm home.
