4870x2 Screws
871 Views 7 Replies 4 Participants Last post by  kow_ciller
What size screws does the 4870x2 use?
EDIT
I know they are M2's.
Not sure which though.
http://www.fastener-express.com/inde...S&Category=248
1 - 8 of 8 Posts
I'll look, but You can buy some here:
http://www.crazypc.com/products/9363X2.html
Those are for a certain waterblock.
Well, thought it might have helped...
I'll keep searching.
Do you know if the 4870x2 has the same screws as the 4870? I can use my micrometer to measure the 4870 screws.
Should be the 8mm long standard flathead M2 screws.
Yup, just eyeballed one of them with a ruler, 8mm long.
Thnx man, just purchased a pack of 50.
+rep.
you can get a free pack of screws from arctic cooling in case you didn't want to spend money on them.
1 - 8 of 8 Posts
