1 - 6 of 6 Posts
<a href="http://files.zenixstudios.com/40812.7.JPG" target="_blank">http://files.zenixstudios.com/40812.7.JPG</a><br />
<br />
<a href="http://valid.x86-secret.com/show_oc?id=132407" target="_blank">http://valid.x86-secret.com/show_oc?id=132407</a>
Nice, I also hit the big 4ghz, but can you get it stable? <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
Probably yeah, what is a good stability test? I have been doing all sorts of stuff already for an hour with 4.0ghz I think I can pass stability.
Orthos Prime, two instances of SP2004, or two instances of Prime 95 will get you at pretty much full load.<br />
<br />
If you can run a test like this for more than 15 minutes or so its a good sign. <br />
<br />
Testing for a much longer period of time, like overnight will show long-term stability
Nice going..<br />
<br />
Also try dual runs of Pi32M.. this is also a good indicator .. then Prime away.<br />
<br />
Keep on going up.
<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /> <br />
<br />
Way to go!
1 - 6 of 6 Posts
