1 - 10 of 10 Posts
As title.
What are the monitors that supports 4K, GSYNC, HDR10?
I know the Asus and the Acer 144Hz but they costs too much.
Is there something cheaper with this specs, even 60Hz is good for me.
there is a preditor as well, I have the 1440p 144hz model but they also make a 4k g-sync 60hz model. Are you not gaming with it? cuz if you are gaming then I highly suggest you go with 1440p 144hz and g-sync right now. not to mention there isn't a gpu out there that will keep 60fps on extreme graphics in most games. I have a 1080ti and it gets 60fps in some games but not all in 4k.. its much better to use 1440p and take advantage of the highest settings and high frame rates with a 144hz monitor than it is to go with a 4k monitor and be stuck at 60fps/60hz on medium graphics... just my .2 cents.
forgot to mention its made by acer and they make fantastic monitors. I LOVE mine and I got a deal on mine and paid $399 for it which now you cant really touch one for under $500-$550
4k gsync montiors (aoc and acer) are using kinda oldish panels and hdmi 1.4 so eerything not connected by displayport will be limited to 30fps.
Mostly a lurker
We started the move on 4k 144hz... while we don't even have local dimming 1080p 144hz monitors or 4k 60hz monitors. Not sure even if rtx 2080ti will beable to push 4k 144fps in new games :p
Discussion Starter #8
I really don't need more than 60Hz, specially now that games are moving towards raytracing.
with raytracing on games will return to run 30FPS even on Tis.
so 4K 144Hz is and will be monitors for fortnite only.
I want a 4K 60Hz HDR GSYNC monitors at less than 1500€...
As title.
AOC has a unit launching year end,
much cheaper then whats on market at the moment :)
1 - 10 of 10 Posts
