4x WD 1TB RAID5?
300 Views 9 Replies 7 Participants Last post by  noahmateen1234
I have a PERC 6i coming. Will there be any issue with installing Vista on that size partition?
1 - 10 of 10 Posts
yes it will. if your raid card support it
/agree
There isn't going to be any limitation by Windows? I thought you could only have a 2TB partition for the boot partition.
no there isn't. But i would go with the 64 bit version of windows. but i think you are ok
i actually believe thats true. you have to make it GPT or something weird.. and unsure if the boot partition can be GPT..
Originally Posted by Maddog7771
well if you are doing raid 5 isent the only total usable amount going to be say 2tb?
Nope, should be 3 GBs.
And yes, Windows bootable partitions can't be bigger than 2TB. But all you need to do is make a smaller partition on those drives of like 50GB or so (unless this is an everyday rig and not a server)....but in both cases I would just suggest getting another smaller drive and leave the TBs to storage only.
So I should go with 4x640GB?
Or 3x1TB. What would be faster?
i would go with
3 drives in raid 5 for OS
then 3x1tb in raid 5 for storage
that is of course if $$ isn't a huge factor.
1 - 10 of 10 Posts
