1 - 4 of 4 Posts
Hi everyone,
I currently have my PC audio routed through a Creative USB sound card via the 3x minijacks into the 5.1 phono inputs on my Yamaha AV reciever. This basically works for everything and I get 5.1 for everything from games/movies/music etc. It sounds 'fine'/'great' (I'm not an audiophile as such, lol).
I'm now moving my PC into an enviroment where I'll need a long cable run to get the PC's video/audio to the TV/recieved (possibly 7.5m if we elect to make the cables tidy/out of sight!).
I'm trying to find out if I can simply run a 2nd HDMI cable from my Titan XP (2016) to get 5.1 from games?
I understand I can just bitstream any video files with a DD/DTS/whatever soundtrack through the HDMI to the reciever, but I can't find much information on games.
Some people say it will work fine, some people say you'll only get PCM stereo unless the game supports some kind of DD/DTS/Whatever output. The last time I tried this, I only got stereo in games.
Have things changed recently in the last few years? Should connecting a 2nd HDMI cable to my video card allow it to pass 5.1 audio through for games or if I want an easy life should I just buy 3x decent long-ass minijack->phono cables and just stick with what I have now?
Hope this all makes sense. Thanks so much!
PC Gaming 1337 Enforcer
Yes it will work fine natively. It's better than your sound card setup even, as you will be sending uncompressed 5.1 signal and use the A/V receiver's DAC. You just have to make sure the A/V receiver is enabled as a 2nd monitor, then you can select it as an audio device. This is how I play most of my games.
Thanks for the reply! I actually plugged things in the other day and things worked right away! Didn't even need to sacrifice a single chicken! Kind of shocked! :O
Have a great day!
Where do you plug your monitor then? To the gpu?
I'm wondering if this will work: DP to monitor, HDMI to avr just for the 7.1 audio.
1 - 4 of 4 Posts
