1 - 3 of 3 Posts
okay, ive got an 80mm fan that i'd like to put up front. i marked the two bay door things with a sharpie and measured it all out just fine... my problem is, what do i cut it with? lol sounds kind of dumb, but i really dont know, i guess i could ask my grandpa about his dremel, but is there anything easier just for cutting plastic that i can do, that would be accurate enough because ive got about 4-5mm clearance above and below the fan hole... any suggestions?
Dremel.
SNERP!!!
You can use a little hacksaw if you like.
1 - 3 of 3 Posts
