I have 8 drives, so I'd need two 4-drive 'hot-swap' bays.Originally Posted by DuckieHo;13096921
They are called hot-swap bays.
There are different types.... 1-6 drives, tray/trayless, with/without fan.
I already searched Newegg, directly from Sharkoon's site.. Amazon, as well.Originally Posted by corky dorkelson;13097036
newegg.com -> Hard Drives -> HDD Accesories (then sort price HIGH to LOW)
You will find what you need there.
There are dozens of companies that make hot swap bays. They have been used in servers for over a decade.Originally Posted by Track;13097008
I actually found one from Sharkoon that has 3, but it's not sold ANYWHERE.
It's like two were made and no forum posts were ever created about them.
Well, if you had searched newegg you would have found no less that 8 different models that fit your criteria.Originally Posted by Track;13097105
I was under the impression that only Sharkoon made them. Not sure why.Originally Posted by corky dorkelson;13097323
http://www.newegg.com/Product/Product.aspx?Item=N82E16817998069
http://www.newegg.com/Product/Product.aspx?Item=N82E16817998061
http://www.newegg.com/Product/Product.aspx?Item=N82E16817998146
http://www.newegg.com/Product/Product.aspx?Item=N82E16817994027
http://www.newegg.com/Product/Product.aspx?Item=N82E16817993021
http://www.newegg.com/Product/Product.aspx?Item=N82E16817707117
I believe all those models have a built-in fan.Originally Posted by DuckieHo;13097388
If the drive density is greater than 1 per bay slot, I recommend a built-in fan. (i.e. 4 HDDs in 3 bays)
^That. Also, at NewEgg:Originally Posted by DuckieHo;13097274
Expect to pay $70-100 for a 4-bay trayless bay with a fan.
Search eBay: http://shop.ebay.com/i.html?_nkw=hot+swap+bay+4&_sacat=0&_odkw=hot+swap+bay+5&_osacat=0&_trksid=p3286.c0.m270.l1313
Lian Li makes a pretty one with a 120mm fan (but no ejection):
^ Bump ^Originally Posted by Track;13097364
I've narrowed my choice down to three:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817994113
Anyone have an recommendations?
