500FSB quad CPUz rejecting validations
625 Views 14 Replies 5 Participants Last post by  G|F.E.A.D|Killa
ok i pushed and pushed to get 500fsb on a quad and on a nforce board and well if i validate it says rejected, any one know why. i need a good validation file
http://valid.canardpc.com/show_oc.php?id=520052
1 - 15 of 15 Posts
have you got the latest version? i ran into this prob last week, they must have ended web support for older versions
edit - get version 1.50
yea, im using 1.50, says in the left hand corner of the FAILED validation
i need this validation to shove it in ihatethedukes face
my submit is working as well, weird. has that version worked for you before?
Originally Posted by Dryadsoul View Post
It worked for me:
nice OC, and i love that board, but mine is special cause its on a nvidia board.
I had a similar problem about a month ago, it turns out that they added a lot of sensitivity to the validation system to block some abuse that was happening, according to one of the canard forum admins. They said it would be fixed in an upcoming version. Not sure if this is still the case, Ill see if I can find that post.
Here it is:
http://forum.canardpc.com/showthread.php?t=32858
yea find it, cause my OC is 100% valid, hell i spent awile tweaking setting to get it.
I'm sure you've tried re-downloading it in a separate folder to see if you just have a corrupt download, but I will suggest it just in case.
tried that too, even got it from a different place and even used a different program to unzip it.
I just clicked the submit button on the online validator a few times out of frustration and one of them validated...
This is the "off chance" one that validated: http://valid.canardpc.com/show_oc.php?id=503341
Have you tried running the same OC with an ATI card?? Maybe it's an AMD support problem.
ummmmm what?
Ummmmmmmmmm yeah, AMD is ATI...
Having another double shot now....
LOL XD its all good.
1 - 15 of 15 Posts
